win 95 problem
Old 04-05-03, 12:30 PM
ZORA
Angry win 95 problem
hi
i have win 95 i lost every thing in my computer . now when i start the computer it dose not load window95 it stops at a black screen that display a message.
starting windows 95...
type the name of the command interpreter (e.g., C:\WINDOWS\COMMAND.COM)
C>
my computer is COMPAQ PRESARIO 4660
I DO APPRECIATE YOUR HELP
THANK YOU
Old 04-05-03, 01:22 PM
Received 96 Votes on 88 Posts
Check your bios and make sure you have the proper hard disk listed.
Old 04-05-03, 02:50 PM
Sounds like you may have possibly caught a virus somewhere. You need a Win95/98 startup disk to be able to do anything now. If you don't have one, get one from a friend.
You will also need Fdisk put on the disk, you will have to run "fdisk /mbr" to re-write the Master Boot Record. That may solve your problem. On the other hand, you may have to reinstall your Win95.
Good luck!
One more thing: you absolutely need to run a full anti-virus scan on that computer. You also need to make sure you are running good AV software 24/7 on that computer, with full protection.
Old 04-05-03, 07:54 PM
tae's Avatar
tae
tae is offline
Boot disks can be downloaded here:
http://bootdisk.com/bootdisk.htm
try this fix from microsoft:
To resolve this problem, use the MS-DOS 6.x Upgrade Setup Disk 1 to restart your computer, and then use the SYS command on drive C. To do so, follow these steps:
Place the MS-DOS 6.x Upgrade Setup Disk 1 in drive A, and then restart your computer.
Press the F3 key when MS-DOS Setup starts to exit MS-DOS Setup.
Type sys c:, and then press ENTER.
Restart your computer.
Or try this:
Start your computer with the win 95 Startup Disk created during Setup or downloaded.
Make a backup copy of the current MSDOS.SYS file by typing the following lines at the command prompt:
c:
cd\windows\command
attrib c:\msdos.sys -r -s -h
ren c:\msdos.sys msdos.xxx
Use the SYS command from the Startup Disk to transfer the system files to the hard
disk by typing the following lines at the command prompt:
a:
sys c:
Replace the new MSDOS.SYS file with the backup copy by typing the following lines
c:
cd\windows\command
del c:\msdos.sys
ren c:\msdos.xxx msdos.sys
attrib c:\msdos.sys +r +s +h
Shut down and restart the computer.
