Olympus D-380 Camedia
I have figured out how to do most everything with my new digital camera, except: quick deleting of stored pix.
I know how to delete one at a time, but not all at once.
Is there a way? My Kodak at the office does it, but the Olympus has me stumped. (no great feat, that!)
Try this, straight from the manual (p. 62):
Couldn't decipher some of the pictures (tried to describe them.) Anyway, basically it says to go to Card Setup and select All Erase. Of course, you could do a Format also. Basically the same thing. Format may take longer.
Good luck!
All-frame erase
1 Display the top menu in the playback
• Press O (camera?) with the lens barrier closed.
• Press O (block?)
2 Press > to select MODE MENU
3 Press ^v to select the CARD
tab, then press >
4 Press ^v to select
CARD SETUP, then press >
5 Press ^v to select
ALL ERASE, then press O (block?)
Note that selecting FORMAT will
erase all existing data.
• Press O (block?)
tab, then press >
Good luck!
Go here:
http:http://www.olympusamerica.com/cpg_se...ad_manuals.asp
and go through the steps and then either download or open the manual:
http://www.olympusamerica.com/files/...ce_English.pdf
select camera operation, then scroll down to playback, and thenerasing pictures, then all frame erase(page 62). you will need adobe acrobat reader to view it
