KazzaHack?
Old 06-19-03, 03:28 PM
silentmystic
Exclamation kazaa-particapation level means/is what
i was curious doesnt the particapation rating mean your speed and not the amout of files i mean for a test i put in over 200 songs in the audio file restarted and still said im a (4) as with how it was with 2 songs in it
Old 06-19-03, 04:23 PM
tae's Avatar
tae
tae is offline
not speed, it shows the difference between your uploads and downloads. If you only download and nobody takes from you, your level will be low. If you let people take alot, but you don't take much, your level will be high. The higher your rating, the better your chances for getting what you want. the higher ratings can kick off someone with lower ratings.
http://www.kazaa.com/us/help/glossar...tion_ratio.htm
Old 06-19-03, 06:49 PM
notuboo's Avatar
I thought it was a speed thing. I have a K-Lite Master (1000) ...
We open our archive every so often but just use my computer as the gateway to our home network. But we leech like everything normally.
Old 06-20-03, 06:13 PM
tae's Avatar
tae
tae is offline
klight has a default "hack" that lets your rating always be 1000, no matter what your actual ratio of uploads/downloads.It, and several other things, are listed under "Options/more options" The one thing about ratings and speed: the higher the rating, the more users you can connect with, so you can get the file from more users, which can increase the speed of the download quite a bit.
Old 06-20-03, 07:11 PM
notuboo's Avatar
I read the link listed above. Had no idea that's how it worked.
It explains why the high ranking. We d/l max number allowed and allow 25 uploads. Movie files are big with users when we open archive.
That explains it....
Old 06-30-03, 12:24 PM
Ashley
http://kazaahack.250x.com
link a friend gave me... lets you hack kazaa and have the rating you want
