Compaq Presaio
Old 10-02-03, 12:39 PM
REALTYTIP
Angry Compaq Presaio
Problem---After using for a period of time, the computer just freezes up and will not respond at all. I have tried taking everything back to original config.(operating system)(even changing the operating system). Still the same problem! Any suggestions?
Robert
Was Windows ME-- Now Win 98 Sec Edition
Tried a different hard drive and have removed and swapped memory RAM chips. Still freezes up after using for a period of time(no set period of time).
Old 10-02-03, 12:47 PM
Plumber2000's Avatar
Check for and remove all spyware from the system.
Old 10-02-03, 12:53 PM
green jacket's Avatar
What method have you used to "take it back to the original configuration"? What operating system (windows)?
If it is a hardware problem, it is likely to be a faulty component causing a fault during normal operation.
Other possibilities: A bad stick of memory (RAM), or a hard drive with one or more bad sectors. Chances are this has something to do with a software corruption/incompatibility.
Give us some more info. about what it does, when does it happen/what initiates a freeze or significant slow down?
gj
Old 10-02-03, 07:53 PM
T
I would suspect some bad RAM. Software will very rarely cause this symptom, it is usually hardware.
Old 10-02-03, 09:29 PM
tae's Avatar
tae
tae is offline
could also be a heat problem. Have you checked the fan in the power supply or on the chip, possibly one on the video card?
