Screensaver
Old 10-26-03, 04:19 PM
wingplow
Screensaver
Does anybody know where I can download a screensaver that will display the time.
Thanks
Old 10-26-03, 04:47 PM
kaybyrd's Avatar
wingplow,
If you are using Window95, 98, etc. you should already have one on your computer. I believe its under 'marquee'. You can make it show the date, or you can change it to some personal text. Once you find the correct screen saver (sorry, am currently using Linux so I can't check the name for you right now), click on the settings button to change it to the time, and also how you want it to display ie: bouncing, moving slowly across the screen, etc.
Kay
Old 10-26-03, 04:48 PM
C
If you are running windows, that is available as a choice in the standard screensavers. Right click on the desktop, choose properties, choose screen saver, 3D text, select Settings, select time. Then adjust the other things you want as far as speed, pattern, color, and such are concerned. This will display the system time.
Hope this helps.
Old 10-26-03, 05:04 PM
kaybyrd's Avatar
Thanks Chris, I was way off on the name of the screensaver wasn't I?!
Kay
