backup error!
Old 10-26-03, 10:41 AM
las
backed up files to C-DRIVE
I have windows 98se I did a back up I backed up my files to the C-DRVE,When I finished It said back up Is complete with some errors reported?The computer can still operate like this right?
I moved this to it's own thread.--Tae
Old 10-26-03, 10:43 AM
las
above post was suppose to be seperate post
I meant the above response to be a new thread
Old 10-26-03, 11:47 AM
C
las,
It can. The types of errors would be what mattered. If the files had symbolic links with them, that would generate an error because the symlink could not be backed up unless the file to which is linked is backed up with the directory structure intact.
Check your log to see what the errors were.
Old 10-27-03, 05:27 AM
las
some errors no big deal?
So then If what you indicated Is so It's no big deal to have a few errors then right?
It ain't going to hinder the operation of the computer?
Old 10-27-03, 06:16 AM
B
backup TO c drive?
Did you mean you backed up the files on the c drive to a CD or other media?
What were the errors?
What did you use to do the backup?
Yes, the computer should operate ok.
Old 10-27-03, 06:47 AM
las
Microsoft backup-untilted
I didn't put a disk In.I just back up to the c-drive so I presume It's all back up & on the C- DriveExample:C:\mybackup.qic
took about three and half hours to defrag also..so I presume It's because the c Drive had a lot more info stored on It.What you say?
Old 10-27-03, 07:17 AM
I say that defeats the purpose of doing a backup at all - what if you can't boot your C-Drive?
Old 10-27-03, 08:03 AM
B
yep...
What files did you backup?
Sounds like what you did was backup files on the hard drive to the same hard drive. All this does is give you a quick restore if you delete one of the files. It does nothing to recover the files if the hard drive crashes.
The purpose of back-ups is to be able to recover the files in case of a hard drive problem. You backup the files onto some kind of removable media or on-line storage. This used to be done using floppies. But with files getting so much bigger and people having so many more files, floppies are too small. CD burners are so cheap today, most are using them. You could burn a CD-RW, but with CD-Rs so cheap, its just as easy to burn one of them and build up a library of back-ups.
Another option is a zip drive.
With the files on a removable media. even with a hard drive crash, you still have the files.
Old 10-27-03, 08:38 AM
las
Yup I understand
So Is there any way of undoing what
i did..all I did was create a bunch more stuff for the hard drive to look after
i want to undo everything?
Old 10-27-03, 11:24 AM
las
C-DRIVE
Do you think It Is taking up to much space on my c drive or not enough to worry over
just let it go at that?what ya say?
Old 10-27-03, 01:43 PM
C
Unless the backup files serve some purpose, delete them. I thought you made the backup in order to burn it to a cd or export it somewhere.
Old 10-27-03, 01:59 PM
las
How to delete that back up file?
I'm not sure how to delete It could you help?I do not seem to get the opportunity
to delete them please explain?
Old 10-27-03, 04:57 PM
las
Going to disagree for now?
Oh I think has far as windows 98se goes
I might be able to get away with what I did..I'll just write It all off has experience
thanks for all the help
Old 10-27-03, 05:09 PM
C
C:\mybackup.qic
If this is how the file is named simply right click on it and select delete.
Old 10-28-03, 03:34 AM
las
I deleted the backup
I should of known how to do something has simple has that..well It's done just went Into my computer and right clicked It
& It's all deleted..I think I saved close to 500 mb of space.Thanks a bunch
Old 10-28-03, 03:41 AM
las
2.05 G.B free space
I checked and done a belarc advisor and I now got 2.05 G.B of free hard drive space now....good lesson learned thanks a lot for your help.
Old 10-28-03, 04:28 AM
B
You're welcome
No go get that cd burner and do a proper backup.
