WINDOWS XP, Icon
Old 11-03-03, 02:41 PM
rayd51
Question WINDOWS XP, Icon
How do I go about putting an Icon (such as Word) into the toolbar at the bottom (next to Start).
Old 11-03-03, 02:47 PM
I assume you mean in the "Quick Launch" bar - where "Show Desktop", "Internet Explorer", etc. icons are?
The easiest way is to click and drag from the desktop to the Quick Launch bar - it won't remove your desktop icon doing it that way either.
Alternately, you can right-click the Quick Launch bar (not where an icon is) and click "Open Folder" and add the shortcut there - then it will show-up in the QL.
Old 11-04-03, 08:00 AM
rayd51
I have W98 on another computer and I have shortcut icons at the very bottom of the screen right next to START. I wanted to do the same with the XP but apparently it isn't set up like W 98.
I tried the right click suggestion on the Quick Launch toolbar but "Open Folder" didn't appear. Instead such items like Std button, address bar, links, lock, etc. came up.
I wasn't able to click and drag from the desktop to another screen as I have to undo the drag in order to open the other screen.
Appreciate any other suggestions.
Old 11-04-03, 09:43 AM
Right click on a blank area of the lower task bar, select task bar, select quick launch, and the quick launch area appears. Now drag and drop the icon there.
You can read about this in Help, type quick launch in the search window.
Hope this helps.
Old 11-04-03, 10:20 AM
Yeah, it sounds like you don't have your Quick Launch bar open yet.
Chris is almost right - it's Toolbars, though, not Task Bar (at least in mine it is.)
Old 11-04-03, 11:17 AM
Linux overload, have to use memory to recall Windows stuff. Memory getting old. Needs frequent refreshing.
Old 11-04-03, 03:35 PM
rayd51
Thumbs up
CONGRATULATIONS !! Your Instructions worked perfectly. Thank YOU very much.
