Rnaap
Old 11-06-03, 03:57 PM
gidawes
Rnaap
What is Rnapp?
thanks.....glenda
Old 11-06-03, 04:50 PM
tae's Avatar
tae
tae is offline
Go here for removal info if needed:
http://www.modemhelp.net/newsletter/...atrnaapp.shtml
RNAAPP (Remote Network Access Application) is a core executable for Microsoft Windows Dial-Up Networking. RNAAPP can create a problem when trying to get Internet access by sometimes sticking in memory from a previous session, or too early in a dialup attempt, thus making your system believe that a connection is already established. The error messages "Dial-up Networking could not-establish a compatible set of network protocols…", "No dial tone", "Unable to Open Communications Port", "The Line is Busy…", "The Modem is Being Used…", and "Error 602: The Port is Already Open" are all common errors that you may receive with RNAAPP improperly loaded into memory.
Old 11-06-03, 05:12 PM
gidawes
so dumb question here.........if I'm not on the internet....then rnaapp shouldn't be running in the background?????
thanks....glenda
Old 11-06-03, 09:22 PM
C
Windows loads lots of things in the background if they are consistent with your use. If you have dial-up networking installed, it makes sense to have it ready when you dial your ISP. It saves time.
Hope this helps.
