File extensions
Old 11-17-03, 05:10 AM
File extensions
I have a bunch of digital pictures that I've saved into a file. There are a few that have the extension .psf. What exactly does this mean? I can't seem to be able to open them either.
Old 11-17-03, 05:45 AM
Jack,
If you search for "file extensions" on the Internet you will see a large list of sites that will help you determine what file extensions go with what programs. On the first site I looked at, www.filext.com, I looked up psf, and found 7 listings. The one that makes the most sense, based on your reported activity, is "PhotoStudio Graphic". There is a link there pointing to www.xnview.com, where you can download a free viewer for these sort of files.
You might also want to check the users manual for your camera, as you may inadvertently have it set in a way that is not convenient for your picture vieweing.
If this is not correct for these files, then I recomment that you search further, either on the site I mentioned, or on other similar sites.
Old 11-17-03, 05:49 AM
I believe that is Palette Storage Format for Photostudio.
