Computer Desktop
Old 11-22-03, 05:24 PM
JHarv45
Computer Desktop
I have a folder named My Briefcase on my desktop, but when I double click to try to access the folder nothing happens, it wont open, can someone help me with this problem?
Old 11-22-03, 06:51 PM
tae's Avatar
tae
tae is offline
here's a couple links with some basic information about "my briefcase":
http://www.winplanet.com/winplanet/tutorials/1074/1
http://www.techtv.com/callforhelp/st...5963%2C00.html
Old 11-22-03, 11:17 PM
JHarv45
Computers
Thank you but neither one of the links helped me with my problem, I need to find out how to access the My Briefcase folder on my desktop, I double click the folder and nothing happens, I right click it, then click open & still nothing happens, someone please help me
Old 11-23-03, 01:16 AM
Terminator20's Avatar
Run anti virus software and after you do that run scandisk or norton disk doctor to check your hard disk for errors.
Old 11-23-03, 08:51 AM
You might need to re-install it, if it fails to run.
You can delete the current My Briefcase, then right click on the Desktop, select New, select Briefcase, and a new one will be created. Then you should be able to run it.
Hope this helps.
Old 11-23-03, 12:13 PM
las
try right click
I know a person can set there mouse up so you can only open a icon by right click then left click open..amounts to same thing thou
You can also set things so just one left click opens icon[Instead of two]these computers are a little bit too adjustable?
Old 11-24-03, 05:30 AM
I think Chris is correct
The icon is a shortcut. Either it has become corrupted or the folder is no longer on the hard drive.
Are there any documents in it? If so, you may want to go to explore and look for the folder or do a search for the folder (or files if you remember the names).
If you don't need any of the docs stored in it, just delete the icon and create a new one as Chris pointed out.
