cookies??
Old 11-26-03, 05:18 PM
errodri61
cookies??
Hello,
i just installed win-2000 pro in my pc and i try to get access to the nestcape wep page to check my emails and i get a message the reads "
Cookies are disabled.
You will need to enable cookies before you can use this site.
also i'm trying to get access to my banking and its not leting me in.. how can i fix this problem??
Thanks!!
Old 11-26-03, 05:26 PM
C
Click: Edit, preferences, privacy and security, select the option to enable cookies.
Hope this helps.
Old 11-26-03, 05:28 PM
errodri61
i try that in nestcape and IE and all cookies are enable..
Old 11-26-03, 06:14 PM
C
Good. Glad it worked.
Old 11-26-03, 06:17 PM
errodri61
NO!! sorry... i mean, all cookies are enable but still does not work
Old 11-26-03, 07:41 PM
tae's Avatar
tae
tae is offline
Are you running a firewall of any sort, like zone alarm, or are you running a popup stopper? Also, make sure the time and date on your computer are set correctly.
Old 11-26-03, 07:53 PM
errodri61
yes, i'm running zone alarm. i did check the setting and the are allowed. again i did put this new OS win-2000 pro. is there anything within the OS that may be causing this??
Old 11-26-03, 11:06 PM
tae's Avatar
tae
tae is offline
win 2k shouldn't stop you. Did you check the time and date settings?
Old 11-27-03, 07:53 AM
errodri61
yes i did, i notice the date was of.. i will try it again
Old 11-27-03, 08:00 AM
C
The date and time need to be the right date and pretty close time in order to synchronize with some services.
Old 11-27-03, 08:06 AM
errodri61
now the time and date are correct but i still have the same problem..
Old 11-27-03, 09:17 AM
C
The script picks up a cookie on redirect to the mail url. This cookie retrieves your aol screen name, probably by matching the aol cookie for screen name. Then it redirects again to the login / sign up page.
This is running a java script. Do you have JRE or VM greater version than 1.2 installed? You may get the cookie error when the Java engine is actually the problem. You can get Java from www.sun.com no cost or obligtion.
W2000 may not come with this. I was surprised to find that XP home did not come with it, either.
Hope this helps.
Old 11-27-03, 09:24 AM
B
other security settings?
Aren't there other security settings in W2K? Perhaps these are set too high.
Are you still getting the same error message about cookies?
Have you tried the MSN web site using the exact wording?
Old 11-27-03, 01:11 PM
las
we need cookies
It's just that you need to clear the cookies out after you do your banking..history and such.Don't block your cookies you need them
just remember to clear them from time to time
Old 11-27-03, 09:40 PM
errodri61
i should mention that i did upgrade from win-me to win-2000 pro with out formating the drive... does that make any differents??
Old 11-27-03, 10:42 PM
C
We can blame it on the upgrade. What we needed was a culprit.
It is hard to beat a clean installation.
Hope this helps.
Old 11-28-03, 04:15 PM
tae's Avatar
tae
tae is offline
now that your date is set correctly, you should clean out your old cookies,run ad aware or search and destroy,reboot, and then try it. The cookies should be under c:/Documents and Settings/Administrator.
