Link Window won't open.
Old 11-29-03, 04:56 PM
T
Hi all,
When I click on a link that suppose to open a window. but it's does not do so. It's has no problem of linking to different pages. I am using window2000.
Thanks
Tran
Old 11-29-03, 08:14 PM
R
Do you have a poop-up stopper of any sort installed? What browser are you using?
Try clicking on the link while holding the control key down.
Old 11-30-03, 12:31 PM
T
I don't have any pop up stopper and I use window 2000.
Thanks
Tran
Old 11-30-03, 01:37 PM
tad214's Avatar
john 3:16
hi,
sounds like you need to either repair IE or reinstall it. let's us know what happens.
Problems with IE: Click Start, Settings, Control Panel, Add/Remove Programs, select Internet Explorer. Select remove. A dialogue box will appear. Choose the option to repair Internet Explorer. Follow the prompts. Restart the computer.
if you need a link for the previous version of IE let us know.
Old 12-01-03, 05:49 PM
Could be scripting errors, could be a virus, could be any number of things. If you are not running the most recent version of IE, you should upgrade (it wouldn't hurt to uninstall, then upgrade, since you're having problems.)
Also, make sure you run AdAware and SpyBot S&D (the links are in the Computer FAQ at the top of the forum.)
Good luck!
