using a TV instead of a monitor
Old 11-30-03, 04:09 AM
gmcfan
Hello all! I have a computer with a Matrox Millinium Video card, and was wondering if I can hook it up to a TV that doesnt have an imput for a monitor cable. Is there an adaptor that I can plug into the Card, and then into the back of the TV, like an RCA setup? Or do I have to go and by a TV for this?
Old 11-30-03, 07:18 AM
R
* Edited - This has nothing to do with the question *
Old 11-30-03, 09:52 AM
C
If the card has TV out, it can be connected. Check for TV out on the card or in the owner's manual.
Old 11-30-03, 11:26 AM
tae's Avatar
tae
tae is offline
Which model matrox do you have?
Do you have rca plugs on the tv? Maybe something like this would help:
http://www.cablestogo.com/product.as...2012&sku=27991
They have a pretty good selection of different cables.
You could always hook the computer to the vcr if the tv doesnt have anything. Do a search for "pc to tv" or Matrox Millinium (whatever your model is) to tv.
Old 12-01-03, 05:45 PM
You can get a VGA to NTSC adapter fairly cheap.
About 10 years ago when I bought my first computer (a Hewlett-Packard of all things), this is exactly what I did - I almost miss using that 27" TV for gaming
I used something like an AiTech adapter or something like that to get an RCA video out and it also had a VGA output (to connect both the TV and a monitor, if you want.)
I tried a search over at TigerDirect.com and came up with <a href="http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=316&id=3174">this</a> - take a look and get an idea for what you want to use. A TV is not going to have as high of resolution as a monitor, but it works just fine.
Good luck!
