Printer shareing
Printer shareing
I have two computers one laptop and one desk top both run windows XP my connection is DSL and I am using a router for the lap top.
Can I use the printer hooked up to the desk top from a remote location when I am on the laptop?If so how?
Thanks a million this is the best site
Your post is a little confusing, but I am going to assume that both computers are properly connected to the router and that you can explore each computer from the other. If this is not the case then you need to make it so, or connect the two computers in some other manner.
In your printer setup on the desktop there will be a tab for sharing. Share the printer on the network. Next you configure the printer on the laptop, but instead of installing as a local printer you browse for it on the network and install it there.
Obviously your desktop computer must be turned on to print through it.
Yes they are correct
Yes they are both hooked up thru the router the laptop is wireless and has no printer.I can be on one computer and my wife on the other at the same time but only under diffrent screen names.I will check out my printer setup now tank you very much.
An easy way to install the desktop printer is to browse to it from the laptop via the Network Neighborhood. Once you see the desktop machine, then under it should be the Printers folder, and then you just double click on the printer and it'll install it as a local printer on the laptop.
I have all my machines in my house printing off one file server machine that has 2 different printers set up on it.
Okay I am running W2K and she is running XP. I have my Laser shared and I use it all the time, connected to my PC. She attempts to get to the printer through my computer in Network Places but it comes up with needing a password? I never set a password other than for the basic network and the password set for her doesn't allow her into my computer.
I have her set with the same rights as me ... not administrator but all other rights. Any ideas? Of course this is after having to reformat and reload a couple days ago!
