Canon Printer Problem
I have a Canon S520, a little under two years old. For a long time the printer worked flawlessly. Now, in order to get a good quality print, with proper colors and absence of lines, I need to run the cleaning option almost every time. Could the use of less expensive aftermarket (non-Canon) inks have something to do with this?
If you've been using refills, then you need to toss out the cartridges and buy new ones - those things can only be refilled about 5-6 times (if you're lucky) before the nozzles start going bad.
Good luck!
Good luck!
Do you mean nozzles in the cartidges, or in the printer? (Pardon my ignorance.) I have not refilled the cartridges myself. I bought the actual cartidges (although I have no idea if the company from which I purchased them uses recycled cartidges).
The nozzles are in the cartridges themselves - in the bottom where the ink comes out.
If you do not use a cartridge for some time, the nozzles can become cluttered with dried-out ink or if you take the cartridges out frequently, the nozzles can become damaged.
Try taking a damp paper towel and dab (don't rub) the cartridge nozzles on the paper towel. Sometimes this will help clear them out. If that doesn't help, pop in a new cartridge (not a recycled or refurb'd or refilled cartridge) and give it a try.
My guess is the cartridges you are using are just second rate and not made to last - those nozzles can be very touchy sometimes.
Good luck!
Good luck!
