"right-click menu" is very slow to open
Old 01-08-04, 06:32 PM
lucman2
Hi,
I have a WinXP pro, 1.2Ghz/512Mram and it suddenly developed a problem with being very slow during the following:
right click on start
right click on anything
opening word or excell
I've defragged, virus scanned, ran ad-aware to no avail
Does anyone have any idea's for resolving this issue?
Appreciate it,
Mark
Old 01-08-04, 07:37 PM
C
Check system processes for one taking the CPU's time. A runaway process. Then kill the process and see if the system will stabilize.
Restarting the computer should accomplish the same thing.
Hope this helps.
I did find this:
Norton's last "live update" introduced a problem with the MS Office plug
in.
Solution - from the Norton AntiVirus screen, click on "Miscellaneous"
under the Options button, then on that screen disable the "Enable Office
Plug-in". Close AV, and things should be fine....
Old 01-09-04, 12:05 AM
steve_gro's Avatar
Received 1 Upvote on 1 Post
Try the above-mentioned fixes; but here's some more food for thought:
There were two less than stellar Windows XP updates (#811493 and #815411) that you can remove through Control Panel > Add/Remove Programs (or Google them first for more info). If you remove them and they weren't the problem, they should show up again in a future Windows Update session.
Also, there is the possiblility that an errant app is causing this. Some possibilities are: winzip, roxio, and intellipoint. I've found the latter two to be somewhat problematical.
Here's an article that I came across that you may find interesting:
http://www.experts-exchange.com/Oper..._20672546.html
Good Luck,
-Steve G
Old 01-10-04, 08:58 AM
lucman2
...just to let everyone know.
I went and updated Norton anti-virus and performed another system scan.
Norton found and deleted 3 trojan's and everything is back to normal.
Thanks folks!
