Hi Guys,
HP Pavilion, 266MHz processor, 32 Meg RAM
Had something weird happen, don't know what to do now, any help would be greatly appreciated.
I installed 128 Meg RAM, and two new printers.
No problem at that point, when restarted Windows found the new hardware and all went as normal until I loaded the Software Cd into the CDRom. The system would not open the CDRom, so figuring something glitched I shut down the computer to reboot.
During boot procedure it went through the normal bios boot then gave me a screen full of error messages and booted to the DOS C:prompt and no further. I've checked everything I know to do and I don't see a problem other than the Himem.sys is not present.
I pulled the 128, checked setup, all appeared ok, but error messages persist.
Here are the error codes :
The following file is missing or corrupt : C:\Windows\Himem.sys
There is an error in your Config.sys file at line 6
Windows Expanded Memory Driver Version
Copyright 1988 - 1999 Microsoft Corp v. 4.95
EMM386 not installed
XMS Manager not present
The following file is missing or corrupted : C:\Windows\Himem.sys and C:\Windows\IFSHLP.sys
Warning : The high memory area (HMA) is not available
Low memory (below 640K) will be used
C:\>C:Progra~1\McAfee\viruss~1\scanpm.exe C:\
Bad command or file name
Cannot find Win.com Unable to continue loading Windows
CONFIG.SYS FILE as shown in DOS
Rem to make Dos Boot diskette ; see file C:\Dosboot\Dosboot.txt
dos=high,umb
buffers=40
device=C:\windowshimem.sys\testmem:off
device=C:\windows\Emm386.exe
Rem the below DOS CD Rom driver is not required to run Win 95
Rem Device=C:\cdrom\FDataCD.sys/D:IDECD000/C:170,15,376
AUTOEXEC FILE as shown in DOS
C:\>Progra~1\McAfee\Viruss\command
@ IF Error/pause
@ Echo off
Path C;\Windows;C:\Windows\Command
Set buffer=A220 15 D1TZ
Set SNDscape=C:\Windows
Thank you in advance for any help/advice you can give.
AdrianRead More
I keep having trouble with "iamapp". I keep getting "iamapp(not responding) continuously. I cannot run liveupdate with Norton Anti-Virus due to a "lu1840" error saying it's running in background. This has been for a few days now. Any help would be appreciated. Thank you!! DaveRead More
