erasing cd-rws
cd-rw's
Well I'm back as I said I would be.
I do not know how to erase a file from a cd-rw.
Could you please explain how it is done. I can amend or change a file but I cannot erase or delete one. I have tried with windows and my Recordnow-sonic software.
Thank you
Pete
Thank you
Pete
cd-rw
I do not have nero but I do have Recordnow-sonic and I just learned how to erase the unwanted file.
I open the program and when I view the files on the disc and hilite the one I want to erase a red x appears allowing me to erase. WHEW!!
I'm glad for me and you.
Does your Nero work about the same way?
BTW, thanx to all for your help.
Pete
Pete
peterr,
I'm still confused over your procedures. Do you do all your work on the hard drive and then back up at the end of the day or are you reading/writing to the cd-rw all day instead of the hard drive?
If you don't want a stack of CD-Rs, I'd still recommend a minimum of three CD-RWs, a weeks worth would be better. Rotate them daily. Expect the worst to happen - a hard drive crash AND corrupted backups. Rotating through three or five CD-RWs is not a difficult task.
cd-rw
Sorry about the confusion, Bob.
I work on my hard drive during the week then on the weekend I back up my work to floppies,i.e., budget changes, new doctors reports etc.
Now that I can amend and erase specilfic files ,I'll be using cd-rw's as they have more room. I still keep the original work on the hard drive in my doc's to be amended or erased, as the case may be, for the next weekend.
I hope this clarifies my procedures.
It must be frustrating tutoring novices who do not always give you all the details.
Thanx for the help.
Pete
Thanx for the help.
Pete
No problem,,,
You got some very good advice on back-ups from everyone. Yet, you seemed to disregard that advice as somewhat irrelevant.
That advice is still valid. Summed up:
1. Don't rely on a single cd-rw. When you need it, you may find it is corrupted. In your case have at least four (4) and rotate them. Use disc A the first weekend of the month, disc B the second weekend, etc.
2. CD-Rs are very cheap. You can often find a spindle of 30, 50, or 100 on sale. On sale, the final cost is around 10-15 cents each. Use a fresh one every weekend and put the date on it. So what if you have 52 after a year?
3. The backup process can be automated. There are tools available for this. Recordnow-Sonic might even have a tool with it.
4. If this is for a business, weekly is not often enough. If this is for a business, then daily back-up is cheap insurance.
5. I know you think this is overkill. But if you ever have a hard drive crash or any problem that requires a reformat, you will realize its just good sense. A simple thing like a virus is enough to cause this headache. It happens to everyone.
Did I leave anything out, guys?
cd-rw
Bob
I did miss the tip about changing cd-rw's that often; I'm used to floppies which I changed about once a month.
I think the folks here covered all the bases and I'll be back with more questions.
Besides being informative, this is a friendly forum unlike some I've been to.
Some advisors forget they too had to start somewhere.
After being around for seven decades I never saw a pc until recently so it's a task to grasp skills needed to keep up.
One issue at a time.
Pete
Pete
