Case Fans
Old 01-23-04, 05:03 PM
Terminator20's Avatar
Case Fans
Can someone give me a website that has top quality case fans for cheap price's
Old 01-23-04, 05:23 PM
<a href="http://newegg.com">NewEgg.com</a>
<a href="http://tigerdirect.com">TigerDirect.com</a>
<a href="http://maxcooler.com">MaxCooler.com</a>
<a href="http://casecooler.com">CaseCooler.com</a>
<a href="http://mwave.com">MWave.com</a> (not quite as cheap as others)
<a href="http://buy.com">Buy.com</a>
<a href="http://thenerds.net">TheNerds.net</a>
That should get you started. Also check <a href="http://techbargains.com">TechBargains.com</a>, <a href="http://pricewatch.com">PriceWatch.com</a>, and <a href="http://nextag.com">Nextag.com</a> for prices from different stores.
Good luck!
Old 01-24-04, 11:16 PM
Thanks for all the sites here thats perfect! Now for my next question.
After looking at some different fans on one of the websites I noticed that they have have fans from 40mm all the way up to 120mm. Because I built my own system, bought my own case, it did not come with a manual. So, how do I know what size fan the back side of my case can use?
Old 01-24-04, 11:34 PM
Typically the back side case fans are 80mm - but, you should check the specs on the case to be sure. Or, just measure across - the size is just the width across the fan. You should be able to get a real good idea of what size it should be - they are standard, 40mm, 60mm, 80mm, some 90mm, and 120mm.
You should be able to figure it out - if not, tell us the model of case you have and someone can find it for you.
