Computer lockup on TV
Old 01-26-04, 12:32 PM
Narroc's Avatar
Hi,
I have a Genuine Intell x86 family 15 model 2 stepping 9 with 295 mb ram.
With brooktree audio & video capture.
Mother board is an Asus P4V533-MX.
I'm running W98SE.
Now I have a Dynalink TV card and after an hour the picture suddenly freezes althought the sounds keeps going.
Can any one please advise why this happens and what I can do about it ?
Also Can some one give me the mickeysoft site to get the W98 SE. shutdown patch please.
Thanks
Old 01-26-04, 03:06 PM
C
This is a handy source of fixes and discussions for problems with Win 98se.
http://www.aumha.org/win5/support.htm
Hope this helps.
Old 01-26-04, 08:53 PM
It Wasn't Me!
Old 01-31-04, 12:00 AM
Narroc's Avatar
Computer lockup on TV Computer lockup on TV
Well,
Interesting enough, I tried to alter the power in Bios, But that didn't help but I already had penicillin virus on the puter appartenly it comes with the M/B setup but it never seemed to do any thing so I downloaded AVG from the net and next thing Penicillin must have woke up and started to do a scan then I had a red screen with a virus alert which I said diable and then after AVG had done a scan and found 2 virus which it healed.
The 2 viruses where Trojan horse downloader. A, and the other was Java/ByteV . Penicillin also said it had found a couple viruses too
However since then the TV program will run without freezing, Only time I had a freeze was when I had Eudora and Netscape opened at the same time so I suspect it ran out of resourses.
Is there any way to overcome this as I would like to work as I watch TV ?
Old 01-31-04, 07:09 AM
R
Buy a better computer.
You may be able to update your existing one, but it is probably less aggrevation and cheaper in the long run to buy a new one now.
Old 02-02-04, 12:22 AM
Narroc's Avatar
I've just spent several hundred dollars to up grade to what I've got now only a couple weeks ago. I had an 330 computer and a dynalink modem (ADSL) which kept refusing to work when the temp got over
27-28 degrees Cent so I got a new modem (a Web excel) and one thing lead to another and I finished up with this up grade.
However what should I have to get more resources ? I've already got 295mb ram would more ram help? or what.
Old 02-02-04, 12:42 AM
tae's Avatar
tae
tae is offline
read here:
http://home.cfl.rr.com/bjp/Resources.htm
Seems eudora uses alot of resources
