win xp problem
win xp problem
hello,
i done a clean install on a dell system that had win xp on it. when i brought it back up, everything was fine, except there is no sound. it says sound device not found. does anyone have any idea what the problem is here?i installed the same xp cd that came with it. i have ran out of ideas. can anyone help me out with this one? thanks in advance. DALE
Just to clarify: this component worked properly before you re-installed XP?
In Start, Control Panel, Sounds and Audio Devices, does it window show any audio device installed?
Try restarting the computer.
One thing to try:
In Start, Control Panel, Add Hardware, run the wizard to detect your hardware as the instructions direct.
One thing to try:
ok, thanks a lot. yeah, when i went to device manager, it said no devive found. so the driver issue would make sense, considering it is intergrated audio. thanks again for the help. as always, i came here and my problem was solved. lol you guys have a good day, and GOD BLESS.
