explorer causing a lot of "Illegal Operation" messages
Hi
My Internet Explorer browser is causing a lot of "Illegal Operation" messages. Any ideas what it might be? Thanks if you can help. P.S., running Win 98.
Try running IE repair (go to Add/Remove Programs and click Remove, then IE will ask if you want to do a Repair.)
Make sure you're up-to-date - what version are you currently running?
If that doesn't help, uninstall IE and reinstall.
Good luck!
Good luck!
Installing explorer again
Well I took your advise and re Installed the explorer again
I was getting a lot of that also Illegal operations pop ups
tired of all this?Maybe longhorn will be perfect when It gets here
but It will be so expensive not everyone can afford
Virus
I don’t remember the name of it but about six months ago I got a virus that prompted an illegal operation then shut down. Don’t know if this helps but you might do virus scan? Windows web site has a removal tool for this virus
Also it may not be IE's fault, do a spyware scan and check your installed Browser helper objects as well, either of these could be causing the problem.
