Win 98 and scan disc
Old 03-04-04, 10:31 AM
W
Angry Win 98 and scan disc
I shut off everything but Explorer and Systray, scan disc still get stopped by a "running" program.......any ideas?
Old 03-04-04, 11:12 AM
Shut down and restart Windows in Safe Mode (press F8 after the POST beep) - run defrag and scandisk from Safe Mode.
Old 03-04-04, 01:19 PM
las
scandisk
You can get away with running a quick system check with
scan disk without going Into safemode...usually I find If I delete the temporary files and cookies and clear history I can get away with a quick version of scandisk without going Into safemode
same goes with ad-aware I can do the quick fast version of ad-aware
without going Into safe mode but I have to go Into safemode to
do a defrag there Is no other way to complete It with my O.S.
windows 98/SE.I presume you got windows 98 right..!
Old 03-04-04, 02:43 PM
tae's Avatar
tae
tae is offline
las...
why can't you defrag from windows? Do you get an error message or does it just hang and take forever? Windows 98 is notorious for scandisk/defrag problems, but there are workarounds/problem solvers. Even though it is best to use safemode, why not try to get it fixed?
Old 03-04-04, 02:58 PM
las
safemode
I believe In going Into safemode to do maintenance esp.
with my O.S. but that Is mainly for a defrag cause I'm getting
away with the short quick version without going Into safemode
but has far as a defrag goes there Is no defrag unless It Is
In safemode cause It won't finish otherwise?It took me a long time to learn that I figured I could schedule maintenance with
windows 98/SE no way with windows xp maybe yes thats a differant story.That Is how you fix a problem Is by going Into
safemode I just hold and keep tapping the f-5 key works
everytime..take a little bit of time getting Into safemode thou..!
Old 03-04-04, 05:29 PM
C
One interrupting nemesis may be the screen saver.
