incredimail
Old 03-08-04, 06:21 AM
tad214's Avatar
john 3:16
Angry incredimail
hey guys,
when i try to open my incredimail, i get this error:
INCMAIL caused an invalid page fault in
module IMSUPP.DLL at 0167:0169a3ba.
Registers:
EAX=00000000 CS=0167 EIP=0169a3ba EFLGS=00010246
EBX=ffffffff SS=016f ESP=0073eb00 EBP=0073ec0c
ECX=00863e80 DS=016f ESI=00863e80 FS=4747
EDX=0073eb10 ES=016f EDI=0073eb94 GS=0000
Bytes at CS:EIP:
8b 08 50 ff 51 20 8b f8 85 ff 7c 26 8b 44 24 08
Stack dump:
00000000 0073eb10 0073eb94 00863e80 00000000 0169915b 00863e80 0073ed68 01699030 0169a5b0 00863e80 00000000 00000000 000000c8 00000008 00000000
could someone tell me what could have caused? and how to fix it?
i don't want to have to uninstall it, because i will lose all my stationary that i have collected up. looks like i'm going to have to go a little bit deeper in the files system to manually fix it, i'm just not sure where to go.could someone give me a little help here? thanks in advance for the help. DALE
Old 03-08-04, 06:48 AM
C
What operating system are you using? Win98, ME, XP?
If this is windows, have you restarted the computer and still get the error everytime?
Old 03-08-04, 06:59 AM
WorldBuilder's Avatar
I have never used IncrediMail, but I suspect your problem comes from spyware. Download AdAware from here and run it. I will say this: Since I have never used IncrediMail, I DO NOT KNOW if running AdAware will screw it up or not. Incredimail (from what I know) is loaded with spyware natively, and running AdAware may render it completely useless.
I would also add that IncrediMail is generally not a good e-mail client. It's cute, to be sure, but all that stationary and images that makes it cute just makes the e-mail messages unnecessarily large, chewing up internet bandwidth, and generally not doing anything positive. When it comes to e-mail, just stick with the basics. I do understand that appeal of IncrediMail, but it is not even remotely utilitarian. Not to mention the fact that most people don't even get the stationary effects you send unless their e-mail clients can handle the html code in the message! Most programs do have html enabled for private addresses, but people who are on work or corporate e-mails will almost always have that shut off for the sole purpose of NOT allowing that extra html code to take up space.
My $.02...
Chris
Old 03-08-04, 07:06 AM
tad214's Avatar
john 3:16
i am running win 98, i have ran s&d, no spyware. yes, restart does not fix it.
p.s. this problem, among others, started when i installed the following files to go with bible pro software.
Microsoft Universal Data Access 'MDAC'
thanks again
Old 03-08-04, 09:23 AM
tae's Avatar
tae
tae is offline
Have you tried reinstalling incredimail?
Old 03-08-04, 12:04 PM
Unfortunately, I don't know IncrediMail very well. I have seen it in action a time or two, but know little else. I have asked some MS friends of mine what they think, but they don't know why MDAC would screw it up in any way. I'll continue researching it for you, friend.
I also know nothing of this Bible Pro. I saw it once when I was restoring a PC at a church that called me up for some help, but I know nothing of that program, either. Very sorry.
I would like to reiterate something, though... I very much suggest not using IncrediMail at all. I have seen some people use it for home businesses and the like (creativity businesses where the stationary and smilies are neat), but other than that, there is no real use for it. As I said, IncrediMail has a tendency to turn a regular e-mail that would normally be 8K into 200K for no real reason!
IF you're main reason for using IncrediMail is smilies and animations, there are better alternatives, I believe, and could make some suggestions. IF your reason is the stationary, well, IncrediMail is probably your best choice.
Just consider it, friend.
As tae said, you might try to reinstall it. If you think that might wipe out your settings, try to back up the files that hold those settings. Other than that, I will continue to ask around and will let you know if I here anything. Good luck!
Chris
Old 03-08-04, 04:21 PM
tad214's Avatar
john 3:16
Talking
greetings all,
i would like to let everyone know, that i have gotton rid of incredimail, and went back to outlook 6. it isjust to much of a headache for me. it runs great for a while, then all of a sudden, it crashes and you can't do anything with it. so, thanks for the help and replies. i will just stick with outlook. have a good night, and may GOD bless you.
