CD-ROM problem (W95)
Old 03-13-04, 03:54 PM
houseman's Avatar
My old PC (1997) has Windows 95. It has always run fine, but recently the CD-ROM suddenly stopped working. When I insert a CD in it, the yellow indicator light blinks a few times, then goes off.
When I click on "Run ...", I get a message saying "d:\ is not accessible. The device is not ready."
When I click on "Properties" in Device Manager, it says "This device is working properly."
Yeah, I know it's W95, but I kinda like it and I'd hate to let it go.
Thank you.
Old 03-13-04, 04:45 PM
C
Try swapping the cable, then the drive. This drive is a bit long in the tooth.
Nothing wrong with Win95 if it works.
Old 03-13-04, 05:37 PM
tae's Avatar
tae
tae is offline
and try multiple cd discs. Could be a bad disk.
Old 03-13-04, 06:04 PM
WorldBuilder's Avatar
These guys are right. It's probably just that the CD drive has finally failed (being a mechanical device, they all die eventuallt). I doubt anything is wrong with Windows. Try their suggestions, and if all that fails, you can buy a new CD drive at a local store for $20 or less. If there are any computer shows in your area, you could get one for even less.
Cheers,
Chris
Old 03-14-04, 06:17 PM
I'd say you're ahead of the game Even if you have to replace the CD drive, you're not doing too bad.
Old 03-15-04, 07:48 AM
houseman's Avatar
Thank you for all your advice. It is much appreciated.
I tried various CDs in the drive. None of them worked, so the problem is with the drive.
I've never opened a PC before, but I guess it's time to start!
Thanks.
Old 03-15-04, 07:59 AM
You're welcome. Even if you've never done it before, replacing a CD drive is about the easiest thing you can do being a first timer. Follow the instructions with the new drive and you shouldn't have any trouble. If you have any other questions, post here and we'll help out, man.
Good luck!
Chris
Old 03-15-04, 09:23 AM
Terminator20's Avatar
Since I just hurd that you never open a pc before, I just wanted to let you know that in all these years you have probably accumilated alot of dust in there. When you replace your cdrom drive, it would be a great idea to blow everything out with compressed air. My best bet is to take your computer outside and do this so that way dust does not get all over everything. Well good luck...
Old 03-15-04, 07:06 PM
C
Don't blow compressed air inside an optical drive.
Old 03-16-04, 07:49 AM
houseman's Avatar
Good advice about the dust...
I'll try and get to it this weekend (procrastinator? who me?) and let you all know how it goes!
Old 03-17-04, 06:14 PM
B
Houseman;
If you never replaced a drive before, it is painless. Just follow the safety precautions of turning off the power, disconect the computer from a power source, don't wear bracelets / rings/ watches/ etc while inside the cabinet!
Also after turning it off, let it sit for awhile ( 10 minutes is usually good) to let any residual power supply, power down. Also, I would suggest, that you invest in a small computer tool kit. They usually cost about 8 or 9 dollars! Cheaper at trade shows! These are antimagnetic and include some good tweezers for those screws!
