useable RAM
Old 03-21-04, 10:53 AM
hvac4u's Avatar
useable RAM
have 512 on a new compaq, only 215 or so is available. should it be more or am i being too picky?
Old 03-21-04, 11:35 AM
Plumber2000's Avatar
512 is plenty
Old 03-21-04, 12:33 PM
B
More info, please
Does the computer only recognize 215 or does it recognize the entire 512 and you are using 58%?
What applications are open when you check the memory? What OS?
Old 03-21-04, 03:07 PM
hvac4u's Avatar
yes about 43% plus or minus available. is this normal, not sure what it should be
Old 03-21-04, 04:46 PM
Well, that all depends on what's running - and what has been running. If this is during normal working hours - progs open, IE running, OE running, AV/FW, etc all running - this it's pretty normal on an XP machine (if memory serves.)
RAM is not so much the important factor - it's the Resources summation that you should be concerned about. Page File usage, CPU usage, GUI, etc etc. Use Ctrl-Alt-Del to see what your resources are looking like - Resource Meter under Win9X.
Good luck!
