Wireless Connection Sharing
Old 03-28-04, 01:10 PM
Tommg
I had a home network using Intel Anypoint (telephone) software. I never used file or printer sharing, only cable internet sharing (on 3 desktops). I recently purchased an SMC wireless router. I have one desktop (formerly the server) wired into the router (WAN). The desktop works great, and so do 2 additional laptops that were never on my home network. The laptops signal is strong everywhere in and outside the home. The laptops are WXP & W98; desktops are W98SE & WME.
The problem is that the 2 desktops formerly on the network receive a wireless signal but will not connect to the internet. Both desktops have an ethernet card and a wireless card. I only want to share my internet connection; not files or printers. The wireless card and router support people are stumped. Any suggestions?
Old 03-28-04, 01:22 PM
R
Try disabling the ethernet cards, either by physically removing them or by turning them off via software.
Old 03-28-04, 02:00 PM
Tommg
Thanks, Bob.
The manufacturers said i need an ethernet card in the desktops. But I disabled them and it still didn't work.
Old 03-28-04, 03:36 PM
R
Have you tried manually telling the wireless cards to connect up and request an IP address?
Old 03-29-04, 10:55 AM
Davejb's Avatar
1. Remove the non-wireless ethernet cards
2. Go into Network options in control panel and remove the reference to the wired cards- reboot
3. run winipcfg and see if the wireless cards are getting assigned an IP
4. make sure the SSID of each wireless card matches that of the router.
5. run the Internet connection setup wizard on each PC and reconfigure to access from a LAN.
Old 03-31-04, 01:09 AM
Stormer
Were you using Internet Connection Sharing to share the internet connection? Remove ICS so that the cards can get an IP from the router and the Gateway setting (the IP address of the router) is correct.
