external hard drive and performance
Old 05-13-04, 12:52 PM
N
Received 1 Upvote on 1 Post
Question external hard drive and performance
I have old ( by computer standards) notebook VIO PCG-SR33 that has only 2gig of space. Assuming if I connect external had drive to it through USB it will slow down
whole system, the question is – Is it noticeable. The way it is set up right now, it’s not the fastest system in the world; in fact, it’s not the fastest in my house…
The USB I am using is a 2.0 hub, that is used for network connection and mouse too.
Thanks,
newbie
Old 05-13-04, 02:04 PM
R
If you have an old computer, then I doubt that it has a USB 2.0 interface.
An external drive does not necessarily slow down your system. The OS should be installed locally, as should most of the traditional applications. I would keep data and large applications on the external drive.
Old 05-13-04, 07:07 PM
WorldBuilder's Avatar
From what I've found out, that laptop does NOT have a USB 2.0 connection, but it DOES have firewire. My advice would be to get a firewire external HDD.
Chris
Old 05-14-04, 08:43 AM
N
Thumbs up thanks
Thanks a lot!
i will persue the firewire optioin & I don't know what is the speed of notepad's USB it's the external hub that is 2.0
thanks,
nebie
Old 05-14-04, 09:10 AM
Ok,
More than likely the USB on the laptop is NOT 2.0. In that case, the speed of the hub won't matter to the external HDD because it would still bottleneck at the laptop anyway. Go firewire for sure. Let us know if you have any other questions.
Chris
