"A runtime error has occured" message.
Old 05-26-04, 05:53 AM
GregH's Avatar
Super Moderator
Recently when on this site I have begun getting the above message with the query, "Do you wish to debug: Line 126 error, Unterminated string constant".
There are different line error messages each time.
I've run Spybot and Adaware and have not uncovered anything.
Is this my problem or this sites?
Old 05-26-04, 09:57 AM
WorldBuilder's Avatar
Assuming your using IE, then you have "script debugging" enabled. Disable it.
In IE, click Tools, then Internet Options. Click the Advanced tab. Under Browsing, there is a box that reads "Disable Script Debugging". Check that and you should be good to go.
Chris
