upgrade operating system
Old 07-23-04, 05:42 AM
JIM2393
how difficult is it to upgrade windows 98 to windows 2000
Old 07-23-04, 05:48 AM
WorldBuilder's Avatar
Throw the 2000 CD in the machine and find out!
Seriously, it's very easy. 2000 will overwrite 98, replacing it, and it does a pretty good job of keeping your settings and what not.
Tip: When going to 2000, switch to NTFS from FAT32.
Chris
Old 07-23-04, 08:13 AM
las
Wait till August
In august you could get windows xp with the new update SP2
If your going to spend money throw It In that direction
pending upon the size of your computer
Old 07-23-04, 02:18 PM
Possibly, but most machines running 98 aren't powerful enough for XP's bloated necessities.
Chris
Old 07-23-04, 03:36 PM
tae's Avatar
tae
tae is offline
if you have enough room on the hard drive, i would let 2000 install itself while keeping 98. You could then use either operating system.
Old 07-30-04, 10:03 PM
iSeal
The upgrade I believe would imply that you'd pretty much have to start from scratch. Reinstall all your programs, reconfigure everything to the way it was.
Win2k is much better in many respects, and I whole heartidly recommend the upgrade. Installing Win2k is a pretty straight-forward process, and you'll find great support for it since any XP compliant drivers/apps are pretty much compliant with it too.
Old 07-31-04, 06:35 AM
AZbowhunter's Avatar
Thumbs up 98 & 2000
I got both on my PC. I had a probm. at first because I put both on the same partition. Make sure you have your hard drive partitions big enough so you can seperate the 2 OS. This works well now.
AZ
