AMD Anthlon Chip
Old 08-27-04, 10:12 PM
fishpounder's Avatar
AMD Anthlon Chip
Just looking for some advice. Building a new 'puter as the last one I built has issues. Was going to use the 1700+ I currently have, but changed my mind. I want new. Got a MSI K7N2 Delta board and wondering what the best bang for the buck would be. Listed as compatable with 3000+ and higher chips,but dont need that high. Thoroughbred or Barton core? Any quality difference betwixt 'em? Looks like 2400-2600 chips are around $100 @ online discounters. I will be having 1GB pc2700 DDR with it. Does anybody know offhand if other chips will work(Anthlon 64,Semperon) in this board? Throw your opinions this way. Thanks!
Old 08-28-04, 02:35 AM
C
According to the information on the manufacturer's website:
? Supports Socket A for AMDŽ Athlon?/Athlon? XP/Duron?/Sempron? processors @FSB 266/333/400
? Supports up to Athlon? XP 3000+ processor or higher
Hope this helps.
Old 09-01-04, 05:24 AM
A
You want a Barton core processor for that motherboard, as they will run at 400 MHz front side bus without a problem on that mobo, whereas, the Thoroughbred probably won't.
Old 09-19-04, 04:17 AM
bowlingpro2501
barton
I have the barton core, quite happy with it.. Ive also heard that, that core can also handle over clocking alot easyer then other cores. which can be a plus. and as said from the guy above me, it is a 400 mhz bus, which is very handy. good luck.
