My E-Machine will not start. Please heLP
Old 09-28-04, 07:14 AM
katiefran's Avatar
Question My E-Machine will not start. Please heLP
My E-Machine 366 IS Tower with Windows 98 os will not start. Last night it worked fine this morning it is dead. It will not make a sound. No lights come on. The plug is in a working outlet in a working surge protector. I did check that. What do I check to find the problem? Thanks for any advice, tips and help.
Old 09-28-04, 07:55 AM
C
Check to make sure that the power cord is plugged into the back of the computer,too. If it still will not start, it could be a blown fuse in a surge protector, or a failed power supply. If the fan on the power supply runs, the motherboard may be fried from a surge. If the power supply won't start, it may have failed due to age or a power surge. If the power supply has failed, it can be replaced. If that does not solve the problem, the motherboard is likely fried.
Hope this helps.
Old 09-28-04, 09:08 AM
katiefran's Avatar
cAN i USE ANY POWER SUPPLY ie, gATEWAY FOR e-MACHINE
Hi Cris, Thanks for speedy reply. I have a larger spare gateway power supply .
Can I try usung this in the e-machine if I can squeeze it in there. Box is about 2 inches longer and 1/2 inch in dept bigger and 1 inch wider. Both say 115 volts. Both have a fan attached. Gateway replacement says Power tronic wk-6145dl3 145 w max. Original from e-machine says il55an elecom corp. model isp 120s. Both say do not remove cover. Thanks for any help.
Old 09-28-04, 09:13 AM
C
The trick can be getting another supply to fit the mounting holes. Some brands of computers have their own dimensions to accommodate.
Old 09-28-04, 09:32 AM
katiefran's Avatar
Can I try it??
Thank you. Can I try it? Will I fry anything/? I think I can make it fit but I wan't to be sure it's otherwise compatible. Do they have differant streangths and can I damage the computer by trying it?? All the plugs seem the same.
Old 09-28-04, 09:50 AM
Kevin_28's Avatar
It shouldn't hurt to try it, as long as you're okay with your case being open.
Most eMachine computers use standard ATX power supplies (the connector will look like a rectangle with two rows of pins). So if both power supplies have the same connector and your Gateway power supply makes your computer work, you could go online or to a nearby CompUSA / Best Buy and get a proper replacement for about $35.
Old 09-28-04, 03:14 PM
katiefran's Avatar
Talking It's Fixed!!!!
It's good again. I bought a power supply the right size at MicroCenter for $40.00. They had a $20.00 sale one but of coursr it was too big. It was so easy and it's good again. I'm happy again!!! Thanks for the help guys.
Old 09-29-04, 07:29 PM
tae's Avatar
tae
tae is offline
SSHHH..... dont tell anyone. We like to keep people thinking that fixing a computer involves some kind of voodoo and magic.
I'm happy again!!!
Good for you. really, to many people are afraid of their computer. They shouldnt be. Maybe you're a computer tech in the making!!
