vB code?
Old 10-31-04, 07:31 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
vB code?
There was a thread that I can't seem to find about resizing an image that is placed in a post.
What is added to the <1mg code to do this?
Old 10-31-04, 08:10 AM
If you're using the HTML tag (< img src= >, etc.) then you would add the attribute width=" " or height=" " and put either a definite size (IE: "100") or a percentage (IE: "100%")
If you are using vB code, I believe it's the same, but since upgrading I can't seem to find anything on vB anymore (it used to be in the reply area to the left of the reply box, but it's gone now.) I'm pretty sure it's the same though, maybe no quotes?
Just use HTML
Example:
CODE and PHP tags are gone in the upgrade too - can't do a good example.
Edit:
Just found the vB code usage page - http://forum.doityourself.com/misc.php?do=bbcode
Seems as though you can't use height and width with vB code - so, I repeat, just use HTML. IMG code is off anyway in this forum (and I believe in all forums at DIY.com)
Old 10-31-04, 08:20 AM
GregH's Avatar
Super Moderator
Thanks
I'll try what you suggested.
To be honest, I'm really green when it comes to "codes" and don't know a vB from an html.
Here is the vB list. A lot of this stuff is still around, just in a different place.
Edit: By the time I crafted my response you too had found the code.
I'll try the html. I may fool with a website this winter so I'll need it for that.
Thanks again.
