BJC 2000 printer only print Colors...
Old 12-04-04, 11:51 AM
meumeuh
Hi,
I just changed the cartridge and the printer prints only in colors and does not want to use the black ink.
I have check the option and everything. I have used all maintenance cleaning possible.
I would think it is hard but what can be wrond ?
Are the two colors (black and colors) do not use the same path to get to the paper ?
Could this be blocked ?
thanks in advance.
meumeuh
Old 12-04-04, 01:03 PM
Is the printer using the colored ink to make black, or is black just not printing? Are you sure that the ink cartridge has ink in it? Did you try a new cartridge?
Old 12-04-04, 01:07 PM
meumeuh
well, i did not try another cartridge as I just changed it and both (color and black cartrige) are new.
But this could happen ?
I will try another one then...
anyway, do you know if the 2 cartridge are using same "tunnel" to get to paper?
Old 12-04-04, 02:46 PM
Assuming that you removed the plastic tape from the cartridge....
Both use jets built into the cartridges. Sometimes the mounting frame gets gummed up from sitting in the park position and needs cleaning. Also remove any accumulation from the park position to keep it from fouling the jets.
Hope this helps.
