Windows troubleshooting problem
Old 12-10-04, 05:58 AM
Good morning. I am having problems with my trouble shooting program. I can open the help program via start, open troubleshooting , select the issue that I want to troubleshoot, then get to the window that reads "what problem are you having." I make my selection in the menu with a "tic", click next and I get a blank screen. Thats as far as it goes. Can anyone explain, or suggest a fix other than reload my os. I am using Windows 98se. as always, thanks in advance
Old 12-10-04, 07:13 AM
pgtek's Avatar
Received 1 Vote on 1 Post
hi
win98 se has lots of updated to download from microsoft.
I would check microsoft for update and they scan your computer for problem.
cheers
pg
Old 12-11-04, 06:45 AM
C
Have you restarted the computer? Does the problem exist in Safe Mode, too?
Old 12-11-04, 07:03 AM
Chris:, yes and yes
Old 12-11-04, 10:10 AM
C
Windows 98 is getting rather stale in my mind. You may be able to look in add - remove programs, add - remove windows components and uninstall the troubleshooter; then install it again. The function is part of Windows, so you should be able to reclaim it. Sometimes it is difficult to troubleshoot problems out of sight.
You could try an in-place re-installation of Windows. This will return all the windows functions and files to the original state. Problem here is that you will need to get many updates to bring it up to where is should be.
Hope this helps.
Old 12-11-04, 10:34 AM
Terminator20's Avatar
WinXP Home for $90.00 bucks man. Save up and buy it. Then you can get SP2 free from Microsoft for it.
Old 12-11-04, 12:40 PM
R
If you buy Windows XP now it will be service pack 2, you won;t need to install it separately.
However, not every computer can (or should) run Windows XP.
