Home 120v non grounded recepticle
Old 12-26-04, 04:05 PM
clarion47
Exclamation Home 120v non grounded recepticle
Older home w/ two wire recepticles ( no ground) should I have concerns?
rewiring w/ ground is not an option as it is extremely costly. If I plug a high quality surge protector to the non grounded recepticle then plug the computer to the surge protector do I have unknown problems. thanks.
Jimmy Jenkins
Old 12-26-04, 04:21 PM
C
A surge protector will have a grounded plug on it and won't fit into a two-prong outlet. A surge protector won't provide a ground for the equipment, if none otherwise exists.
Is the house wired with BX cable?
Old 12-26-04, 05:17 PM
WorldBuilder's Avatar
Not really, if you DIY.
In older homes with no ground, you really, really, really should rewire.
Of course, that's just my opinion, I could be wrong.
But the short answer is that a surge protector really won't help.
Chris
Old 12-26-04, 10:00 PM
Received 1 Vote on 1 Post
The reply below was apparently mistakenly entered as a reply to an unrelated thread in the Electrical forum.
Thanks for your reply. I guess I didn't give enough info. I realize the surge protector has a three pronged plug and that I would have to use a two to three plug adapter on the recepticle and that the surge protector would therefore not be grounded.
Thanks,
Jimmy Jenkins
Old 12-26-04, 10:04 PM
On an ungrounded circuit, use a mode 1 surge suppressor, not a mode 2 surge suppressor. Code requires you to install a GFCI receptacle if you cannot provide grounding and you need a three-prong plug.
You don't need to rewire the whole house. It is usually not too expensive to just have one grounded circuit added for your computers and sensitive electronics.
Old 12-27-04, 02:57 PM
houseman's Avatar
See chfite's question: Is the house wired with BX cable?
If yes, then the metallic sheath acts as a ground wire and you don't need to re-wire the house or that particluar circuit. Simply remove the old receptacle, connect the hot and neutral wires to a new 3-slot receptacle and you're set.
