Backing Up MS Outlook Mail to Disk?
How do I save or even locate .eml files from Outlook to save to disk? It cannot be done within Outlook apparently. I cannot find the files in windows search, nor can my burn software locate them.
Can anyone?
Thanks!
Can anyone?
Thanks!
If you use Outlook you have a .pst file. Notice I said "A pst file". All of Outlooks folders and all your mail are stored in 1 pst file, you won't be able to open that file and extract anything. Make sure you search hidden and system files for it. Also I have seen these pst data files many MB and even over a GB in size, depending on your definition of "disk" you may not be able to back it up, certainly not a floppy, maybe a CDR or DVDR might be required.
The default location is c: -> documents and settings -> yourusername -> local settings -> application data -> microsoft -> outlook -> *.pst and *.ext
The file size depends on how many messages you have saved, remember to empty the junk and deleted items folders, that will cut down on the size.
Now What to do?
Pardon my ignorance guys, but I have located these .pst files (thank you) archive and outlook, but don't know what to do from there. I clicked open but got a dire message about making changes etc. Where do I go from here? Thanks again... and again why isn't this just as apparent and easy as backing up anything else (say .doc) to disk?
Holy Moly what an idiot I am! I am chronically oblivious to the obvious as far as computing is concerned.
I saw the import/export option, didn't follow it, thought it only related to tranferring files and settings to and from another email client.
Thanks for pointing this out, and your patience.
File locations
The default location for the .pst file is buried deeply in the "Documents and Settings" folders. There is one for each user setup in Outlook. To locate the file(s) for a specific user, from within the users Outlook logon click Files > Data Files Management: From the popup select the file and click "open folder"
then copy or backup the file and transport it as you wish.
