Slow Laptop
Old 07-25-05, 09:58 PM
Lightbulb Slow Laptop
Hi,
I have an emachines Laptop (1.53 Ghz, 128 Mb RAM), I am using DSL to access the internet. The Laptop is only 3 months old and when I am on the Internet, it takes forever to move from web page to web page. What is the problem?? How can I improve performance using the internet??
Thanks,
greenda4
Old 07-25-05, 11:05 PM
tae's Avatar
tae
tae is offline
go here:
http://www.pcpitstop.com/internet/default.asp
run the various speed tests and let us know what they are.
Old 07-26-05, 03:44 AM
What OS are you running?
Win XP home, or pro likes a lot of memory. 128 is bare minimum and the machine will run very slow, especially on the internet where you'd be viewing a lot of graphics. You would need at least 256MB, or even better, 512MB of ram.
Good luck...RC
Old 07-26-05, 08:45 PM
Lightbulb
Hi,
I am using WinXP Home and I ran the tests that you suggested and here is the data:
Bandwidth Test = 4567 kbps
Test Details = 3354 kb downloaded in 5.875 secs
Upload Bandwidth = 750 kbps
Ping test Avgs = 70,102,179,102,125,290
Don't know what all this means...Does it mean anything to you guys??
Thanks,
greenda4
Old 07-26-05, 11:29 PM
Originally Posted by greenda4
Hi,
Thanks,
greenda4
Your internet bandwidth looks fine. If you are running win xp then I'd do as what was suggested and upgrade to at least 256mb of ram. Win xp does alot of disk swapping with only 128megs.
Old 08-10-05, 11:05 AM
Lightbulb
I upgraded my memory with a 256Mb stick of RAM and the computer came with 256Mb of system memory, so I should have 512Mb of RAM, which is what I want. However, after placing the RAM in the computer and going to the Control Panel -> System, the system is still showing 192 Mb of RAM. Why doesn't it say 512 Mb? Is the system not recognizing the RAM??
Thanks,
greenda4
Old 08-14-05, 09:44 AM
Your first post stated your pc had 128MB Ram. Did you start with 128 or 256? Adding 256 more would give you 384MB ram.
Sometimes the memory module is a bit tricky to pop into their slots, so be certain you have it seated correctly. After re-seating the memory, check what the reading is in BIOS (during boot-up, usually the delete key, sometimes F2, sometimes something else).
Note: 128MB ram is a BARE MINIMUM for running XP.
Bandwidth Test results: Your connection is fine, speeds reported should not cause slow web page loading.
Check your computer for Trojan Horses viruses and the like.
A Trojan Horse can send your computer to its knees! Several will have it gasping for air.
General cleanup can speed it up as well (temp files, cache, registry garbage). I found a great utility called CCleaner that will do just that.
Hope this thelps,
blinky
