program files
Old 08-01-05, 07:11 AM
P
Received 1 Vote on 1 Post
program files
I removed real player from add/remove then 'search' for remnants but it still exists in my system config utility>startup. I have gone to HKEYS;1-local, 2-root, 3- user, recommended to me and followed directions to 'run' to delete in the right pane but it wasn't there either.
I had a late thought- When I get to my machine at home, if I find Real Player in program files, can I right click it and delete it or will I lose windows files? (Should I create a restore point and back up the registry first?) Thank you
Old 08-02-05, 04:45 PM
sr71000
you should be able to delete that from program files...a restore point isn't necessary, but it's not necessary to remove it either...unless you're short on harddrive space i wouldn't bother with it!
Old 08-04-05, 04:02 PM
P
program files
I'm confused as another message said not to remove it from program files b/c other 'dll' files may be involved. I am not going to fuss about it. Thank you
