paging file
Old 11-02-05, 01:20 PM
paging file
I have a couple of questions for you. First, I am running Microsoft XP with SP2. I get getting an error message that says my paging file does not exist or is to small. I have tried increasing the paging file, but this does not work. When I get the error, evertime I log on, I simply click ok and everyting seems to run fine. Do you know how I can get rid of the error and what is causing it? Secondly, my computer seems slow, how can i speed it up a little, or can I? Thanks for the help!
MRT19
Old 11-02-05, 02:30 PM
R
One reason for your system to run slow is because you don;t have enough swap space, which is what Windows is telling you is the problem. Other reasons are too little memory and not enough hard drive space.
To change the paging file space, follow these directions from the Microsoft Help page:
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
Open System in Control Panel.
On the Advanced tab, under Performance, click Settings.
On the Advanced tab, under Virtual memory, click Change.
Under Drive [Volume Label], click the drive that contains the paging file you want to change.
Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set.
If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Notes
To open System, click Start, click Control Panel, click Performance and Maintenance, and then click System.
To have Windows choose the best paging file size, click System managed size.
For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Old 11-02-05, 03:04 PM
Davejb's Avatar
How much installed RAM?
How much free hard drive space?
Currently allocated swap file size?
Old 11-04-05, 02:16 AM
Page File Error
You might want to read this as it has info on this problem.
http://support.microsoft.com/default...&Product=winxp
