Fuzzy
Old 11-03-05, 07:24 PM
C
Fuzzy
My son installed netzero cd and they requested resolution 600x800 and 256 hi color. I have windows 98. Since he did this, my background is fuzzy and my screensaver changes from red to purple and blue and green, instead of blue clouds. Any help here?? Thanks.
Old 11-04-05, 05:21 AM
John Whorfin's Avatar
You can change the resolution back to whatever it was before, something with more pixels and more colors. This will make your screen look normal again. The lower resolution and color depth is what is making the screen look poor. If you are not sure how to do this, right click the mouse on the desktop itself and choose properties from the menu that appears. Then click the settings tab and this is where you modify the resolution settings.
However, depending on the NetZero program it may not run at the higher resolution (I doubt this but is possible).
If you change the resolution to something higher and the Netzero program does not work correctly you have to make a choice. Which would you rather have, Netzero or better resolution.
