16 bit ms-dos subsystem dl.exe
Old 11-11-05, 03:42 PM
DanHoagy
the NTVDM cpu has encountered an illegal instruction. cs:053aip.0206op:636174696f. choose close to terminate the application.how do i go about fixing this. also another problem im having. windows delayed write failed. windows was unable to save all the data for the file.1182.248.274.139\shared docs\cdex-151.exe. the data has been lost. the error may be caused by a failure of your computer hardware or network connection. please try to save the file elsewhere. pleas let me know what to do further. this is causing slow downloading of websites and sometimes cantgo back to my home page of msn. im operating windows xp
Old 11-11-05, 05:10 PM
tae's Avatar
tae
tae is offline
first, make sure you have ran an antivirus scan and a couple anti spyware/malware scans from an updated program, preferably in safe mode.
you can find download links for many that are good and free here:http://forum.doityourself.com/showthread.php?t=157468
http://support.microsoft.com/kb/314106Troubleshooting MS-DOS-based programs in Windows XP
or try:
Download Killbox from here http://www.downloads.subratam.org/KillBox.exe to your desktop.
Double-click killbox.exe
Click on Tools > Delete Temp Files and click ok.
Select the option "Delete on reboot".
Now highlight and 'copy' (Ctrl + C) the entire list of filepaths below:
C:\Program Files\MsConfigs\MsConfigs.exe
C:\Windows\system32\p2pnetwork.exe
C:\Windows\system32\CMD.COM
C:\Windows\system32\netstat.com
C:\Windows\system32\ping.com
C:\Windows\system32\regedit.com
C:\Windows\system32\tasklist.com
C:\Windows\system32\taskkill.com
C:\Windows\system32\taskmgr.com
C:\Windows\system32\tracert.com
C:\Windows\system32\bt.exe
C:\Windows\system32\z.tmp
C:\Windows\system32\bszip.dll
Click 'File' on the killbox menu at the top and choose 'Paste from clipboard'
The entire list should now be in the "Full Path of File to Delete" field.
To check, click on the dropdown-arrow next to that field.
If you expand it, these lines should all be there.
Then press the red button with a white X in it.
Killbox will tell you that all listed files will be deleted on next reboot, click YES
When it asks if you would like to Reboot now, click YES
If you get a "PendingFileRenameOperations Registry Data has been Removed by External Process!" message then just restart manually.
