New computer - no modem - network card?
Old 11-21-05, 01:52 PM
I am purchasing a new PC, the specs say no modem. Is there some other way that I can connect to the internet? I am upgrading to DSL, I've been reading about internet network card/modems. I assume this is what I will need to purchase. Any recommendations? I don't mind spending to get something of quality.
Thanks.
Old 11-21-05, 02:47 PM
tae's Avatar
tae
tae is offline
so many people have broadband now that phone modems are becoming obsolete, kinda like floppy drives. most new computers come with a network card, either a 10/100 or 10/100/1000, which basically is referring to the transfer speed limit. if you are going to have broadband, either cable or dsl (2 most common) then generally either a network card or usb port is needed, as well as a broadband modem. A combination router/modem would be a good solution, something like this:
http://www.tigerdirect.com/applicati...7810&CatId=159
depending on the computer, you could probably add a phone modem yourself. they are usually around $20.00 or less, and easy to do.
Old 11-21-05, 07:31 PM
Will the DSL provider will supply these items as part of the installation?
OR do I need to buy these items in addition to the standard DSL kit?
Thanks, I'm new to this stuff so I hope I didn't ask the same question twice.
Old 11-21-05, 11:55 PM
tae's Avatar
tae
tae is offline
they usually provide the modem and filters. they can do all the hookup, and install network cards, usually at an extra cost. you would have to ask them.
Old 11-22-05, 04:28 AM
R
If you are buying a new computer, buy it with either an Ethernet connection built in or an Ethernet PCI card installed. Most will be designed/sold this way anyway.
Installing a card after the fact is never as easy as having it pre-installed by the manufacturer. Plus, a direct Ethernet connection is far superior to using a USB adapter.
Old 11-22-05, 08:33 AM
This is what the specs show:
10/100 Base-T Fast Ethernet interface
Should this be enough to get started?
Old 11-22-05, 10:21 AM
R
This is an Ethernet connection. It will do fine for connecting directly to the DSL modem, or better yet to a router that connects to or is part of the DSL modem.
Old 11-22-05, 10:44 AM
I think I have enough information now to know what to shop for. Thanks for the help.
