hyperthreading
Old 12-03-05, 11:36 AM
P
Received 6 Upvotes on 6 Posts
hyperthreading
I want to enable this on my Dell Dimension 4600 xp2 sp2. I got into system setup by tapping f2. I was told the option would be under 'cpu' but it was not there.
Can anyone help. Thank you
Old 12-03-05, 05:46 PM
Got this from Dells website:
To enable or disable HT Technology, perform the following steps:
Reboot the computer.
When the Dell logo screen appears, press the < F2 > key until the computer enters the System Setup program.
Press the < Down Arrow > key until CPU Information is highlighted.
Press the < Enter > key to display the available choices.
Press the < Up Arrow > key or the <Down Arrow> key to highlight Hyper-Threading
Did you do exactly what is says above?
Old 12-04-05, 05:14 AM
D
Received 12 Upvotes on 10 Posts
Do you have a hyperthread enabled CPU?
Old 12-04-05, 05:40 AM
P
H.t.
Yes I found it and it is disabled by default. I took the advice of someone who had a different model and went to cpu and hit enter to see the sub categories. When it wasnt visible I hit esc-hope no damage done. All is running ok. I read enabling it may require some program updates so I'm leaving it where it is.
Thank you
Pete
