Colors in Window XP Home Edition
Old 01-21-06, 05:28 PM
H
I re-installed windows xp on a new hard drive. Having troubles with the colors on my monitor which is an NEC LCD 17inch. Discovered when I go the control panel and then the display icon - the area where you can designate certain colors on different areas - so when I click on colors I discovered there is no RED showing up.
The color on everything does not look right.
Anyone have an idea what I did wrong?
Thanks,
Harlan
Old 01-21-06, 09:39 PM
tae's Avatar
tae
tae is offline
you installed the correct video drivers?
have you looked at the settings on the monitor itself?
Old 01-22-06, 05:57 PM
H
Yes, I have done both. I hooked up an older monitor and it worked fine. Guessing that maybe there is a problem with the monitor.
