Vundo
Old 01-28-06, 06:33 AM
mattison's Avatar
Vundo
Ok guys. How it got there I haven't a clue. Norton can't seem to get rid of it and McAfee had a sequence you went through but that still didn't seem to do it. I still get a pop-up from "I think it's called" winfix, machine slows down and is simply a pain sometimes. Is there anything I can do or is it time to back-up and reformat ?? Adaware daily finds 10 - 15 things and Spy-Bot finds a couple. Norton says it found Vundo and archived it. Bad part about a reformat is that I've got over a thousand songs on here and hundreds of pictures.
Dell Dimension 4700
Windows 2000XP Pro
Old 01-28-06, 06:43 AM
the_tow_guy's Avatar
Received 32 Votes on 25 Posts
Old 01-28-06, 07:14 AM
Good luck with your problem.
As a side note, you will eventually have to reformat anyway, so if it has to be now it may as well be. Start planning on how you will go about doing this now or when the time comes. Figure out where to put the songs and other files while you reformat.
Old 02-10-06, 07:13 PM
Atribune
You can download my vundofix.exe and use it with the following instructions.
Please download VundoFix.exe to your desktop.
* Double-click VundoFix.exe to run it.
* Put a check next to Run VundoFix as a task.
* You will receive a message saying vundofix will close and re-open in a minute or less. Click OK
* When VundoFix re-opens, click the Scan for Vundo button.
* Once it's done scanning, click the Remove Vundo button.
* You will receive a prompt asking if you want to remove the files, click YES
* Once you click yes, your desktop will go blank as it starts removing Vundo.
* When completed, it will prompt that it will shutdown your computer, click OK.
* Turn your computer back on.
Old 02-10-06, 07:20 PM
New Member
You can also run AdAware when windows starts, if AdAware finds this on a normal scan but can't delete it then running the scan when windows starts will allow AdAware to delete the offending file.
Joe
