DVD-RW Letter
Old 03-13-06, 06:53 AM
kolias's Avatar
Received 3 Votes on 3 Posts
DVD-RW Letter
I had to switch my DVD-RW and CD-RW in order to make my DVD-RW the boot drive. Previously my CD-RW was at location (0) drive letter E:\ and the DVD-RW was at location (1) drive letter F:\. After the switch and as per the Device Manager the DVD-RW is at location (0) and I can boot from it now, and the CD-RW is at location (1). However the drive letters on the Explorer never changed (still shows the CD-RW as drive E:\ and the DVD-RW as drive F:\) which is confusing. How can I change the Explorerís drive letters? Thank you
Old 03-13-06, 08:29 AM
R
Windows Help is your friend. Don't be afraid to use it.
I searched on "drive letters":
To assign, change, or remove a drive letter
Using the Windows interface
Open Computer Management (Local).
In the console tree, click Disk Management.
Where?
Storage
Disk Management
Right-click a partition, logical drive, or volume, and then click Change Drive Letter and Paths.
Do one of the following:
To assign a drive letter, click Add, click the drive letter you want to use, and then click OK.
To modify a drive letter, click it, click Change, click the drive letter you want to use, and then click OK.
To remove a drive letter, click it, and then click Remove.
Important
Be careful when making drive-letter assignments because many MS-DOS and Windows programs make references to a specific drive letter. For example, the path environment variable shows specific drive letters in conjunction with program names.
Notes
To open Computer Management, click Start, point to Settings, and then click Control Panel. Double-click Administrative Tools, and then double-click Computer Management.
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
A computer can use up to 26 drive letters. Drive letters A and B are reserved for floppy disk drives, but you can assign these letters to removable drives if the computer does not have a floppy disk drive. Hard disk drives in the computer receive letters C through Z, while mapped network drives are assigned drive letters in reverse order (Z through B).
You cannot change the drive letter of the system volume or boot volume.
An error message may appear when you attempt to assign a letter to a volume, CD-ROM drive, or other removable media device, possibly because it is in use by a program in the system. If this happens, close the program accessing the volume or drive, and then click the Change Drive Letter and Paths command again.
Windows 2000 and Windows XP allow the static assignment of drive letters on volumes, partitions, and CD-ROM drives. This means that you permanently assign a drive letter to a specific partition, volume, or CD-ROM drive. When you add a new hard disk to an existing computer system, it will not affect statically assigned drive letters.
You can also mount a local drive at an empty folder on an NTFS volume using a drive path instead of a drive letter. For more information, click Related Topics.
