Internet connection-modemn
Old 06-09-06, 08:43 AM
2x2's Avatar
2x2
2x2 is offline
Does the modemn need to boot up first before you switch your processor on I always turn everything on at once then I find i have to repair my Internet connection in settings?
I believe the problem was the modemn needs time to boot up first what you all say?
Old 06-09-06, 08:59 AM
What kind of 'modem?'
If it is a DSL device (commonly misnamed a modem) then yes, it MUST be started first.
If it is a real dial up external modem then it should not make a difference although it could if your OS is a plug n play aware OS. However, an external modem would surely complete it's boot sequence prior to the computer OS so again, it shouldn't make a difference due to that.
My guess is that you have DSL and are calling your DSL CSU a 'modem' so it definately needs to complete it's start up first.
Old 06-09-06, 09:07 AM
2x2's Avatar
2x2
2x2 is offline
DSL connection-yes
yes I have a dsl connection and I got my modemn from sasktel
I am on high speed light
Old 06-12-06, 04:41 PM
It is modem ( no N), and still is a modem for DSL, it just works at higher frequencies.
Typicaly, you should tun the modem on first.
Old 06-12-06, 10:26 PM
2x2,
Why are you turning off your DSL modem in the first place? Heck, just leave it on all the time. I've had the same one running for years - no problems doing that. As the others said, the DSL modem must be on before you boot the computer. The computer picks up an IP address from the modem as part of the boot process.
Good Luck,
Joe Michel
Old 06-13-06, 07:46 AM
2x2's Avatar
2x2
2x2 is offline
Thanks
Thanks everything understood now yes I'll keep the modemn on all time
