Keeps Rebooting
Paul
Beyond that sudden rebooting sounds like either a heat issue or malware. Have you tried booting into Safe Mode by hitting the F8 key as Windows actually starts? Does it allow you to get into safe mode?
Paul
What it sounds like is the computer is set to reboot because there is an error. You need to find out what this error is.
What type of AntiVirus software do you have? Is it updated? Do you have an antispyware software?
My guess would be that there is a bad virus or trojan on your computer that has it stuck in the reboot. There is a way to disable this in XP, but I'll have to go find it.
You need to try to boot in Safe Mode and download a good Antispyware and see what it finds.
Here are 2 you can choose from, one is from Microsoft.
Windows Defender: http://www.microsoft.com/athome/secu...e/default.mspx
Ad-Aware:
http://www.lavasoftusa.com/software/adaware/
Here is an antivirus for you if you don't have one, or yours isn't updated. I think it will get spyware off too, I don't use it but I hear it does a decent job. TRY IT FIRST, you must have an AV if you are on the internet.
http://www.grisoft.com/doc/1
You must have a good antivirus and firewall these days. If your antivirus isn't current, it isn't doing any good. SP2 has a decent firewall that will stop most things. (SP1 has it, but not enabled, that is another story)
Anyway, try to download and run that antivirus and one of those antispyware and see what it finds.
EDIT: If you cannot try the programs above because of the reboot before you get into windows, you need to run the system recovery. Once you get to a DOS prompt, type FIXBOOT and then use FIXMBR. I think your boot file might have been messed up. Either from a failed SP2 installation or something.
Go into the bios and watch the temp. monitor and see how high it is getting, the MB could be shutting down the computer because temps are getting to high to keep from frying anything. If temps are ok, then check the voltages(should also have a monitor in the bios), and see if they are holding steady.
I had a server once that rebooted like that. I replaced the flat 80pin IDE cables with round and the issue went away. a way to get an idea what the temp is in the case is to use a meat thermometer and place the probe into the case through a hole. BE CAREFUL OF ELECTRONIC COMPONENTS CONTACTING THE PROBE!!!!
An easy check for heat problems is if you turn the computer off overnight and leave it in a cool room. In the morning boot it up and see how long it goes before rebooting, if the time to reboot is much longer than how long in goes before rebooting after being on all afternoon, it may be a heat issue.
When you describe the computer rebooting, sounds like there may be a video card problem but only if the computer has never fully booted.
Symantec has been know to cause loading crashes but you will usually get the BSOD
have you tried a fresh install of windows?
video could be the issue too like wilkindw suggested. I know some AGP cards need to have power conencted to them in order to boot.
I keep thinking this is a Master Boot Record (MBR) issue, mainly due to the failed SP2 install.
Could the power to the computer have shut off during the night (power outage or something) that caused the computer to reboot. If so, the failed install of SP2 and damage to the MBR would not have been noticed until it was restarted, which happened when the power went out. Some computers will restart after a power outage, while some won't.
I am also thinking, as others stated, this could be a heat issue. But, because of the timing with the issue coinciding with the SP2 install, I am kind of leaning more towards that.
A fresh install of Windows would fix the MBR issue. A repair install would more than likely also, and you wouldn't lose all data.
I hope the OP comes and checks the thread again.
I really love this site!!!
