internet connect sharing
Old 08-15-06, 03:16 PM
fellowesman's Avatar
Question internet connect sharing
my son has two conputers one is running me and is hooked to the net by dsl that runs thru the ethernet/lan connection the other is running 98 and is not hooked to the net
the question is can i put a net work card in the one hooked to the net and one in the other computer to use internet connection shareing? have both on the same dsl line? is this doable
thanks for your time
Old 08-15-06, 05:12 PM
R
If you put two network cards into a computer you will probably confuse yourself trying to program them properly, especially with MyEnemy.
Buy a network card for the Windows 98 PC and buy a broadband router. Plug both PCs into the broadband router, and plug the router into the DSL modem. Done.
Old 08-16-06, 12:10 AM
ICS is more trouble than it's worth nowadays. racraft is right... Router is the way to go. One network card per computer and typical home router setup is so simple that for most routers, you just plug it in and it works without extra configuration.
It's possible that your DSL modem could already be acting as a router (many do have that built-in functionality). What is the model of your DSL modem? You could check with the manufacturer or your DSL provider. If it is already a router, then you just need an ethernet switch.
Old 08-17-06, 05:12 AM
Thumbs up ics
i will e-mail him to get the model of the dsl modem i will post when
i have the info
thanks
Old 08-22-06, 07:34 PM
if the dsl modem is also a router (many are these days) then it probably has 4 lan ports, of which 1 is being used by the 1st computer. put a network card in the 2nd computer, plug it in an empty port on the router, and surf away!
